How low can you go!! 20" 2GS
Im going to get some 20" rims and wanted to know what is recommended for a nice drop, keeping in mind the passengers could be up to 5 people. i was thinking of the TTE 30mm drop but what would you guys recommend....
You can go as low as you want if you have the right wheel fitment. Wheels will travel up and down the same way no matter what height it is. If it rub when you hit a dip or have 5 people in the car, then it's not the right size.
Your wheels specs sounds safe enough, but I really can't comment if it has a nice stance w/ a 30mm drop. Just because you and I probably have a difference in opinion as far as stance is concerned.
