deep dish wheels on my GS400?
Old 01-25-02, 03:18 PM
jbbnet
jbbnet's Avatar
Default deep dish wheels on my GS400?
I want to have that deep dish wheel look on the rear of my GS400, what offset should i look for on 19x10's?
Old 01-25-02, 04:20 PM
///MDex
///MDex's Avatar
Welcome to CL jbbnet.
I would delete this thread and repost it in the Wheels forum.
You are more likely to find the answers you seek there.
Actually, use that search funtion up top before you repost it. There si already a wealth of info in the archives.
Welcome!
HTH
Old 01-25-02, 08:12 PM
GS4Will
GS4Will's Avatar
jb,
offset along is not the only factor that determines the depth of lips, though it is part of equation. however, i have seen the same style rim and same size , say 18x8.5, one is +38 standard disk, and another is +45, deep rim disk, BUT both have SAME lip depth of 75mm, ~3":eek: amazing, but true...
depends on what brand/style rims you like 19x10s will give you lips ranges from ~2"-~4", depends on offset, and disk type..some of the rims that i really like from WORK in 19x10s has 89mm(~3.5" lip), i can choose either +37, or +43 offset and still get that 3.5" lip:eek:
Old 01-28-02, 05:15 PM
tinygs
tinygs's Avatar
Originally posted by gs4will
jb,
Will, are the Equips available with that deep of a lip? I havent gotten any specs from ANY retailers for O-disc type that is larger than 75mm....... Even the measurements you sent me previously were not over an 80mm lip. Can you e-mail me all of the specs for the Equip in 19x10 and 20x10 so that I can point these out to the retailers Ive been corresponding with? Which wheel has a +43 and still maintains a 3.5" lip?
Im not about to pull the trigger again until I have the facts straight about what EXACTLY is offered through Work Co. Japan....
TIA, Tiny
Old 01-28-02, 10:22 PM
GS4Will
GS4Will's Avatar
tiny,
nonono...the 89mm lip is for work KH model 18x10....
here are the lip depth on equips for GS:
19x10, std A-disk +38/70 mm lip , O-disk +45/70 mm lip
20x10, std A-disk +35/75 mm, O-disk +42/75mm
08GS450H
01-21-08 08:18 AM
beauphus
02-25-04 01:23 PM
SC3005SP
05-13-03 08:28 AM
4double0
03-22-03 10:49 PM
whitels
04-17-02 08:29 AM
Quick Reply: deep dish wheels on my GS400?
