wheel stug/lug nut fitment
I bought rims that came off a 350z and they dont fit with my lugnuts. The nissan has a stud diameter of 1.25 and my car has a stud size of 1.5. What can I do to make the rims fit.
Also my cars center bore is 67.1 and the ones from the nissan are 66.2mm will this cause any problems? Thanks
Ok I found out that the 1.25 and 1.50 is the thread pitch so I'll just need to buy more compact lugnuts in a 1.5 and it should fit. Does anyone have an answer to my second question?
mitsu's have a very large hub bore. most other mfr's wheel s don't fit on a mitsu, but mitsu fit s on everything.
those wheels won't fit if that's the actual hub bore measurement as you stated.
This is where Im confused, there are plenty of dsm's running around with 350z/g35 wheels and whem I tried on the volks they mated to the hub. So not sure how to go about this.
the volks have a huge centerbore to accomodate all vehicles, then its' justa matter of using the right hubcentric ring for a perfect fit.
maybe your nissan cb measurement is wrong....
i know lexus wheels don't fit dsm's for a fact. the nissans might have a large enough cb.
Well thats good to hear so it looks like I'll need a 5.9 hubring and I'll be good to go. But I 'll go to a tire shop and get it measured just to be sure. Thanks for everyones help.
DXC
Wheels, Tires & Brakes Forum
15
04-09-22 04:56 PM
