20x9 20x9.5 20x10 ?? for the rear wheels?? what offset are you guys using?
the guys with the
20x9
20x9.5
20x10
or 19x9 19x9.5 19x10
for the rear wheels... what offset fits the gs best ???
and is there any modification needed to fit it without rubbing
and is
20x9 good for the front?? what offset on that???
and what are best tire sizes for these?? best setups (ones with no problems)??
help me out guys
20x9
20x9.5
20x10
and is
help me out guys
20 x 9.5 is the best fit. A 275 fits perfectly on the wheel and with the right offset, you won't need any fender work. A 20 x 10 will work also but if you run a 275, it'll look a little undersized. Nothing horrible, but it's not "optimized". 20 x 9 with a 255 or 265 will work fine...275 is a little big for a 9" wide wheel...it'll bubble a bit...again, nothing horrible, but personally, I don't like the SUV look.
20 x 9.5 with a +38 will sit your wheel out nicely w/o any rubbing or fender work...
20 x 9 can work in the front but you'll have to undersize the tire (245). You can try 255 but it'll rub and you'll need fender work. A 20 x 8.5 is optimal for the front...as for offset, +37 on a 8.5" wide wheel will sit your wheel out perfectly. Plus, if you're wheel is a high disk, it should clear any larger brake kits you might do in the future....
To recap...
Front - 20" x 8.5" +37 running 245/35-20
Rear - 20" x 9.5" +38 running 275/30-20
To recap...
what about 20x9's front and rear
20x9 front +38 with a 245/35/20 ?
20x9 rear +37 with a 275/30/20 ?
Can I use a different offset in the rear to have a bigger lip in the rear?
What is the best set up for 20x9's front and rear???
Originally posted by CamRen
the guys with the
20x9
20x9.5
20x10
and is
help me out guys
the guys with the
20x9
20x9.5
20x10
and is
help me out guys
I personally think the 20x10"R +48 or +50 w/285/30/20 is the best.......
