Rims with lips easier to bend?
Old 02-25-08, 08:18 AM
KayGee
KayGee's Avatar
Default Rims with lips easier to bend?
I posted this question in another thread but it didn't get any responses so I figured that it was worth giving it it's own thread.
What do you think? Is it fair to say that any wheel with 40, 35, 30 series tire height is likely to bend whether or not it has a lip? It seems that wheels with lips are all the rage now but are they easier to bend than wheels without?
Old 02-26-08, 05:54 AM
KayGee
KayGee's Avatar
WOW. This must be a touchy subject. I guess no one has an opinion about this. Maybe I should have asked whether or not I should debadge my car. That should be good for about 5,000 responses.
Old 02-26-08, 10:03 AM
Rexn30
Rexn30's Avatar
Not just normal riding it won't bend.. Its like any other rim don't go hitting curbs and you'll be fine
Old 02-26-08, 10:52 AM
rominl
exclusive matchup
rominl's Avatar
to me it doesn't matter, if you have good quality wheels then the chances are the same. i have seen stock wheels bent (no lip) and i have yet to bend any of my wheels with lips
Old 02-26-08, 07:02 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
depends on the wheel itself more than if it has a lip...
typically though, to compare within a certain style wheel, a wheel without a ridiculous lip will be harder to bend than one with a 3" or better lip... at the same time, a wheel that is multi-spoke will be stronger than a thin 5 spoke wheel... all within a comparable wheel brand...
Old 02-29-08, 12:34 PM
wowitztai
wowitztai's Avatar
depends on the wheels and how u driving with the wheels..ive seen volks rims bent
Old 02-29-08, 01:53 PM
j stuff
j stuff's Avatar
I woud say YES big time hell yes
if you have agressive wheels with big lips and you hit a pothole your chances of bending the lip would be MUCH greater than a full faced wheel.
There is no support for the lip other than the lip itself.
Happend to me.
Old 02-29-08, 02:09 PM
f22cb9
f22cb9's Avatar
In terms of being noticeable...I would say so. However all wheels are just as likely to bend because the inner barrel is not supported at all, just when you bend the inner barrel, you might not notice it or even know...Rims with a lip just have more rim to bend than a full face...
Old 03-02-08, 09:58 AM
Hermosa
Hermosa's Avatar
I would say yes and no. If you had a big lip then the outer part of the rim with the lip would probably have an easier time bending the outer edge since it did not have the center spoke part providing support. There is more leverage for forces. However it would make the outer edge similar to the normal inner edge since there is no center part supporting. The difference is probably negligable though. If the edge of the rims were to curl up or crack anyway which is what would probably hit first then the rim would probably be hosed anyway.
Old 03-05-08, 07:40 AM
dRo15
dRo15's Avatar
I think it's more of the quality/material of the rim and the tire size being used. Obviously the thicker the tire the more cushion between the raod and the rim. There are exceptions though as with stretched tires.
Old 03-06-08, 03:02 AM
CK6Speed
CK6Speed's Avatar
Hard for me to judge since I have bent full faced cast monoblock rims, full forged 3 piece rims with little or a lot of lip as well. If you hit the right pot hole and higher speeds you are toast no matter what.
BGG
08-20-12 08:45 PM
NoLongerA13bFan
SC- 1st Gen (1992-2000)
10-28-09 07:28 AM
johnee78
16
10-21-05 05:42 PM
bmgs400
09-15-05 11:04 PM
Swifty
02-01-02 12:48 PM
Quick Reply: Rims with lips easier to bend?
