iForged wheels?
Former Sponsor
Has anyone else had front end oscillation/balance issues in heavy rain?
I experienced this problem for the first time over the weekend... VERY annoying. Although I absolutely love my wheels (on dry roads), I wont be buying another set because this. The groove in the center that collects the water is to add strength; but a major flaw in my opinion. Do most high-end wheels have a similar problem?
Forum Administrator
Not just iForged with this issue.... I've had that same problem with my HREs as well, but don't drive in the rain that often (heavy or otherwise - only when I get caught out in it going to a meet or show).
There is a thread on this issue somewhere - many 3 piece wheels have this problem depending on their design. edit - here it is https://www.clublexus.com/forums/sho...highlight=rain especially good explanation from our resident wheel engineer Bob in post #38
Maintenance Moderator
Also they now have TPMS adapters that allow you to fit the sensor to the 3pc valvestem (the one that goes in a 90degree angle and comes out the front), and the 2pc valvestem (the ones that on the inside of the wheel). So there is no need for a 2nd hole.
I have the 3pc ones on my new wheels for the VIPER. I'll post some pics of the adapters later. They are cheap too, 65.00 bucks for a set.
Ok that seems like a lot of work just to get new wheels why can't those aftermarket manufactures make their wheels fit like regular ones?
On another question...if I buy wheels from iforged will they send me those valve stems along with those TPMS and lug bolts so I can have it installed without running around trying to find the pieces to complete it?
Oh and does know what kind of TPMS Mercedes use on their cars? Especially 2008 models.
Former Sponsor
The lugs and tps adapters can be included. If you get 2pc modular or 3pc the valvestem is also included.
I don't know what you mean when you say what kind of TPS does MB use.
But if the wheel package includes all that it is less of an issue.
Former Sponsor
What I meant was the type of TPMS used as there are several different ones out there, I assume some are made out of different standards like being able to read actual pressure # and some only give out warning when tire pressure is low but no pressure numbers.
Oh ok gotcha, we have a 07 Rclass, I "think" I can see the pressure (I'll double check tomorrow)
i just received a set of "90 degree adaptors" and all they are are some metal clips, hardly worth $60 at all.
what i got is definitely not
so someone is bait and switching or false advertising. regardless i don't know how i'm supposed turn this clip thing into the pic above.
Dang that's no good. Can you post a few pics of what they sent you?
