Hubcentric rings for project kics 10mm spacers
I wanted to do the same set up as you with 10mm in the front, but I'm pretty sure that kics only makes the hubcentric insert for 15mm and larger. Basically your front will be wheelcentric, but it won't be hubcentric - that's not good. Let us know if you have vibration at high speeds.
I'll probably get the 15mm for the rear, but get 3mm or 5mm for the front.
Going through a similiar fitment as you are, KICS 10mm in the front and 15mm spacers in the rear. I think the confusion for most here is that they don't know how Kics Projects Spacers look like - its a 2 piece system (a thread-on spacer adapter, and a hubcentric insert).
Rokas
08-07-18 09:25 AM
