Hubcentric rings for project kics 10mm spacers
do your spacers have factory toyota/lexus centerbore? if so, and your wheels have the standard 73mm centerbore of most aftermarkets, then a store on ebay sell hub rings in a set of 4 for about $8.
Im using Lexus G-Spider wheels, and the spacers dont have the same centerbore as the stock wheels.. there is a gap. The rear spacers are the same, but the hub rings i have fit over the stock hubs perfectly. I just cant seem to the find the same hubrings in a 10mm, rather than 15mm. Cause the rings are as thick as the spacer.
for some reason i'm confused... you're using factory wheels, so 63.1mm centerbore... how are you using hub rings with factory wheels? afaik, nobody makes a hub ring that fits in a 63.1mm centerbore of a wheel. do your spacers have anything in the middle or just a big hole?
Now.. i have 15mm spacers in the rear, and 10mm spacers in the front. I can find on the internet the hubrings made specifically for the rear 15mm spacers, but i cant find anything for the front 10mm ones. This is all confusing i know.. ill take some pictures when i get a chance.
Go to this site: http://www.evasivemotorsports.com/me...e=PROJECT_KICS
And you can see the spacers and rings im talking about.. i cant hotlink, cause they have it disabled.
Why not go with the H&R?? The set up is one piece (hubcentric). You could use this for the fronts? Maybe I am not sure what you are trying to do here.
Try this link to see what I am referring to.
http://optionimports.com/10656014.html
Hope it works out. Wonder why they make them this way and not as one piece? any pros or cons either way??
