18" 350Z rims on the IS300
The offset is Perfect
Well they fit. The offset is Perfect. Right to the fenders. I needed to have the Rear Fenders ROLLED due to Junk in the Trunk
Front
Offset: +30mm
Weight: 26.56lbs
Tire: 225/40-18
Rear
Offset: +30mm
Weight: 26.56lbs
Tire: 245/40-18
Front
Offset: +30mm
Weight: 26.56lbs
Tire: 225/40-18
Rear
Offset: +30mm
Weight: 26.56lbs
Tire: 245/40-18
Wheel Hub Centric Rings
I am in the need of Wheel Hub Centric Rings. From 55mph-60mph I am getting the SHAKES. So I searched around for 66.06mm outer 60.1mm inner Hub Centric Rings. Nissan/Infiniti Hub Bore = 66.1mm & Toyota/Lexus Hub Bore = 60.1mm. Come to find out it's kinda Rare but I was able to find a company that makes them in Aluminum and has them in - stock. http://www.1010tires.com/hubrings.as...FQZlswodbWkQ-A
They should be in my hands some time next week. I am just POSTING because I don't think I am the only that has the Shakes.
I Got Them In Today
Well I got them in today but now I can't find my Wheel Lock Key.
(66.06mm outer 60.1mm inner Hub Centric Rings)
I know i'm super late but you can also get there here:
http://www.justforwheels.com/index.j...cat=hubcentric
I'm ordering a set myself. I just bought my first IS300 and came with 17" 350z wheels and i noticed they do not have the hubcentric ring in them
