Amistad Wheels Size
i just received one mail from the company in japan they dont have SBC color and they also remove the color from the cataloge. ![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
regarding the offsets i will wait till you give the perfect offset without any mods. i will be happy if you have any idea about this company in US or anyshops can ship to me these wheels.
if there is no dealer in US. So, i will take it from Japan but the mean thing ''Offsets''
a little OT here, i have amistad v's and the center caps are looking really rough (oxidation, etc). was wondering if the OEM lexus caps would fit. diameter is 2"3/4. i searched and could not find any Lexus caps that would fit (max is 2"1/2). i'd appreciate any input on this. thanks. btw, i emailed amistad and waiting for reply re replacements.
Snake, here is the conclusion that Henry (rominl) and I have come up with for you.
20x8.5 +31 High disk (60mm) lip
20x9.5 +35 Super Low disk (99mm) lip
with these offsets you can run a fat tire set-up 245/35 and 275/30 with no fender modifications
hope that we helped you out!
dear anotherLS
this is the end ??? shall i order ??? No Problems ???![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
I have some Pics for my car i take it last week![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
i hope u like the car. but the pic is very bad
i will try to have some high resolution pictures
![](http://7aml.net/uploads/thumbs/7aml-e2104b4d88.jpg)
![](http://7aml.net/uploads/thumbs/7aml-63f153955e.jpg)
![](http://7aml.net/uploads/thumbs/7aml-9f87571fed.jpg)
![](http://7aml.net/uploads/thumbs/7aml-cbc59dac3f.jpg)
Modified With:
Ings+1 Aero Kit
Ings+1 Exhaust System
Ings+1 Emblems
RS-S Ti2000 Lowring Spring
Artisan Trunk Spolier
Tom's Roof Spoiler
BLITZ Front Grill
BLITZ Air Filter
Rays Gram Light 57s Pro Titanum (Removed)
Modified With:
Ings+1 Aero Kit
Ings+1 Emblems
Tom's Roof Spoiler
BLITZ Front Grill
BLITZ Air Filter
Dear anotherLS,
you helped me to much, i already agree with 20x8.5 +31 high disk (front)
so one more little qes: if i go for 20x9.5 +26 (rear) what mods should i do ???
shall i roll the fender from inside or make it little bit wider ( danting job )???? coz if its small job i will go ahead.
and do i need to do camb ?????
coz am interseting to have 20x9.5 +26 (rear) its look amazing for my ride.
for the color i choose Platinum Black
you can run the 20x9.5 +26 you will need to either roll the fender from inside or trim off the fender lip...i know it will look amazing, its up to you though...because at first you wanted no fender modifications, but if you are willing to make it fit with a more aggresive look than rolling/cutting is the way to go!
camber can be adjusted but will affect the toe of the vehicle, plus if you change suspension, it will give some more factory camber, should be good enough..
