Help: its vibrating.
Old 04-28-08, 08:34 AM
Hartawan
Former Vendor
Hartawan's Avatar
Default Help: its vibrating.
my steering wheel and car vibrates. My passenger claims that they feel it too. The vibration is very noticeable at 80+mph. I just did an alignment and is still vibrating. Should I do balancing next? Any suggestions?
Old 04-28-08, 09:47 AM
YoshRX300
YoshRX300's Avatar
I would get all four tires balanced, It should help if un-evenly balanced.
Old 04-28-08, 02:06 PM
radicalrev
radicalrev's Avatar
what may have caused the vibration? just the unbalanced wheels?
Old 04-28-08, 02:24 PM
Hartawan
Former Vendor
Hartawan's Avatar
I also heard bent wheels. I havent fully checked the inside part of the rims but from the outer, my rims are not bent.
Old 04-28-08, 05:19 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
many times you cannot see a bent wheel... you can see some bends, yes, but if a wheel is out of round, it might not be able to be seen unless spun...
when balanced, ask the tech to take a close look for a bent wheel...
as tires wear, they come out of balance... just have them balanced, it's the easiest, most obvious problem...
Old 04-28-08, 06:23 PM
Hartawan
Former Vendor
Hartawan's Avatar
I just took my time looking at the inside parts of the rims and my right front is bent. Wonder how much it is to fix it... at least its the inside part so they dont have to rechrome.
Old 04-28-08, 06:29 PM
radicalrev
radicalrev's Avatar
how bad is the bent?
Old 04-28-08, 07:26 PM
Hartawan
Former Vendor
Hartawan's Avatar
Im guessing wheels arent going to be as strong now? even after repair.
Old 04-28-08, 09:43 PM
radicalrev
radicalrev's Avatar
wew...that small bent will cause vibrations?? wow!! so a bent wheels will always be weak after repairs? didnt know that too..lol...im such a noob
Old 04-28-08, 10:13 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
if its a NOTICEABLE vibration, then its most likely not JUST that.
and wheel strenth is relative, yea, it may be slightly (slightly) reduced after repair but its still plenty strong enough
get the wheels rebalanced before doin anything.
Old 04-28-08, 10:16 PM
radicalrev
radicalrev's Avatar
yeah...cause my stock rims is bent inside..and does not vibrate at all...
Old 04-28-08, 11:08 PM
Hartawan
Former Vendor
Hartawan's Avatar
So balance before fixing? The vibrations is not that strong, but it is noticeable (not scary). I was doing 120 with a NSX just yesterday. My mother sat in the front seat and she felt it coming from the right front.
Old 04-28-08, 11:15 PM
350nub
350nub's Avatar
doing 120 with your mother?? Wow...cool mom! hehehe...
Old 04-28-08, 11:36 PM
Hartawan
Former Vendor
Hartawan's Avatar
I was late for an appointment and it was her fault. The NSX happened to be there and was hauling *** too
The freeway was relatively empty.
Old 04-29-08, 02:39 PM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
Usually a vibration felt in the steering wheels is caused by front tire being out of balance. Though it looks like this situation has been diagnosed.
Quick Reply: Help: its vibrating.
