Wider than 245/45 on Stock 17"?
Folks,
Has anyone tried running anything wider than a 245/45 on stock 17" rims?
Is 255/40 out of the question - can the 8.0" rim handle that width? It looks like the overall diameter would stay within tolerable limits.
Any advice is much appreciated!
Regards,
Eric
Regards,
Eric
There is someone on this forum that has 255/40x17s on the back with stock wheels. If you do a search he has pictures of the setup on his GS. The 255/40s are a little shorter than 235/45s; 265/40s are basically the same height as 235/45s. I had the recomended 235/45s and 255/40s x 17s on my 540i. I never could get an answer of why 265/40s were not used since they match the front better height wise.
Re: 265's on 17" stock
Originally posted by Shogun
Does anyone know if 265's are "doable" on the stock 8" rim?
the tires will buble out and you will probobly loose performance, if you are looking for turning ability and you think more rubber is the answer, well you need a bigger rim too or else the tire's sidewals will keep shifting and it will result in an unresponsive and even un-safe vehicle!
Shogun, I put 265-40-17 on the rear and 235-45-17 on front. The tires are the same diameter. There is no prolem with handling. The rears buldge slighter more then the fronts but not bad. I don't think you could put the wider tire in front. There are in pictures in the suspension section, look under widest tires for stock rims.
MX5
03-07-14 07:35 AM
