Car vibrates at 10-15mph but fine at above speed
Old 06-05-08, 08:14 AM
ChronoJ1
ChronoJ1's Avatar
Default Car vibrates at 10-15mph but fine at above speed
I know for a fact that it's got something to do with my current wheel/tire, because when I had my winter wheels on, no vibration was present.
Do you think it's balance issue? or bent wheel? The vibration only happens in low speed between 10-15 mph.
Old 06-10-08, 11:47 AM
ChronoJ1
ChronoJ1's Avatar
Bump 10char
Old 06-10-08, 07:08 PM
hpfarm
hpfarm's Avatar
I would check your tire pressure, I have seen some low speed shake in the steering wheel as a result of a low tire in my customers cars. Then make sure the wheels are properly torqued, that is the school of hard knocks (I have 19 people working for me in my shop). That is why I'm scared to death all the time.
Old 06-17-08, 07:44 AM
ChronoJ1
ChronoJ1's Avatar
I tried lexus recommended 30 psi, and the vibration was still there. Raised it up to 36 psi, it is still there.
If this is a balancing issue, shouldn't the vib be present at higher speed?
BTW, i'm running on 18s.
lloydc
03-17-11 03:15 PM
brian3268
08-03-02 04:24 PM
hhodgetts
Suspension and Brakes
06-08-02 11:18 AM
Quick Reply: Car vibrates at 10-15mph but fine at above speed
