wheel clearance question
Old 06-25-08, 02:29 PM
black_gs99
black_gs99's Avatar
Default wheel clearance question
i have rotora 4 piston big brake kit in the front on my gs300. i'm looking for wheels for the winter i was wondering if the oz racing super tourismo gt wheel in 18x8 with a 40 offset will clear the calipers? does anyone know?
Old 06-25-08, 04:55 PM
4ntvings
4ntvings's Avatar
think you need to check the disk type of the wheel; that will determine if it clears bbk
Old 06-26-08, 12:55 AM
sleeper408
sleeper408's Avatar
Most likely you will need to run spacers to clear, but definitely contact the manufacturer for the disk type.
Old 06-26-08, 05:25 AM
black_gs99
black_gs99's Avatar
so i'm guessing i need i high disk type rim?
Old 06-26-08, 11:52 AM
sleeper408
sleeper408's Avatar
Yes. That is for BBK clearance. Low disk = max lip.
Old 06-26-08, 12:42 PM
benzo555
benzo555's Avatar
I believe they should. I've seen them clear over Supra TT brakes which are bigger thatn the rotoras.
Old 06-26-08, 02:21 PM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
The only sure way to answer this question is to check the brake template against the wheel.
ddvette9
05-15-17 12:02 PM
YanoYano
Suspension and Brakes
06-09-15 03:50 AM
boosted516
17
08-06-12 09:09 AM
macd7919
07-04-06 11:51 PM
dsouth
04-17-06 08:45 PM
Quick Reply: wheel clearance question
