SSR Competition Wheels
Some guy at work has SSR Competition's on his cherry red MR2, which actually look really good on the thing. But after seeing it on an inferior car, I just can't picture it well on a GS.
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
Actually, TE37s in 18" x 8.5 weigh 7.3 Kg or 16 lbs. You can find technical info about the TEs at
http://www.mackinindustries.com/raysinfo.html
SSR's semi solid forging is a compromise between true hot forging (RAYS) and pressure casting. Hence, mechanical properties would rank in the middle.
The new Le37-T line, having the same offset as the TEs (+40mm) but slightly wider lip, may have smaller clearance for big aftermarket brake calipers.
Mrbig
Wheels, Tires & Brakes Forum
04-17-05 11:48 AM
