Tire Air Pressure Question
This might be a dumb question but does anyone know how much air I should put in my aftermarket tires? Here are the specs:
Front:
19x8"
Tires: Toyo T1-R 235/35/19
Rear:
19x10"
Tires: Toyo T1-R 275/30/19
This is for an 06 IS350 and the factory recommended pressures are 35 in the front and 37 in the rear. Thanks!
Front:
19x8"
Rear:
19x10"
i run those at 40 psi all the way around. imo it helps to keep the wheels protected from bending. that's debateable but i've been running tiny profile tires sinc e 1998 and have NEVER bent a wheel.
cant you re calibrate the tps for whatever pressure you choose to run? i know ont he older cars, there was a button under the dash that would calibrate the sensors for whatever pressure you set them to.
