i changed my rims
Old 02-15-02, 07:55 PM
lexusrider
lexusrider's Avatar
Default i changed my rims
i've changed my rims with different style but same size. i have a pair of nitto tires in the rear and potenza in front. i got them balanced. but the preoblem is that the steering wheel vibrates between 50 - 60 mph. the weird thing is that sometimes it does, sometimes it doesnt. i had it balanced thje second time but it still does the saame. what could be the problem? should i have it aligned or just put my stock rims back?
can anyone help?
Old 02-16-02, 04:01 PM
EmoDragRacer
EmoDragRacer's Avatar
yeah try puttin the stocks on and see if it does it.... if not then rebalancing and realignment..
Old 02-16-02, 06:36 PM
lexusrider
lexusrider's Avatar
thanks
i'll try that.
i'll post what happened
Old 03-12-02, 01:43 PM
yellowis5spd
yellowis5spd's Avatar
Lightbulb
maybe you need the hub centering ring. This will get the wheel hub-centric to your rotor.
Most likely the balance is off. keep an eye on the balancing guy make sure the reading come out to be 0.00 -- 0.00
LexuZ786
03-25-13 10:49 AM
gs350on22s
03-29-09 04:35 PM
RMMGS4
99
03-03-05 08:50 AM
dingo
10-20-03 12:15 PM
ChronoJ1
SC- 1st Gen (1992-2000)
02-26-02 06:51 PM
Quick Reply: i changed my rims
