spacer bolt help!
Old 09-07-08, 02:02 PM
quickex99
quickex99's Avatar
Default spacer bolt help!
Well, I bought some project kics spacers for my car and found out that they are the wrong thread pitch.. they are for a g35.. infinity nissan.. So my problem is that the adapter bolts that bolt the spacer to the hub are not the right size... Does anyone know where I can purchase these bolts in the proper lexus thread pitch? they are 20mm and 15mm spacers .. the 15s have a strange bolt with 4 holes in it for a key to fit in .. the rear 20's have a normal looking bolt.. direct me to a proper place PLEASE!
Thanks in advance
Old 09-07-08, 05:12 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
I would say the manufacturer for the ones with the special looking keyed holes... (unless you can replace with a standard nut)...
you are looking for 12x1.5 mm nuts... available everywhere nuts and bolts are sold - make sure you get a heavy duty nut made for that type of use...
hello1
Wheels and Tires Classifieds
08-21-15 05:24 PM
JH48
11-26-12 10:13 AM
97Soarer
07-01-09 05:16 PM
LEXSTASY
SC- 1st Gen (1992-2000)
12
01-30-09 01:47 PM
Quick Reply: spacer bolt help!
