Got a couple questions..
Old 09-13-08, 02:17 PM
Mesca
Mesca's Avatar
Default Got a couple questions..
1. How much should I torque aftermarket wheels? I do believe I got SplineDrive Cone Seat Lug Nuts from D2 but not 100% sure.
2. How much should I expect to fork out to take out TPMS from stocks, install on new rims, install tires on those, and bolting them all?
3. Anyone got recommendations in Socal to do all this?
4. Falken Fk452 reliable enough to not blow out for non-stretching applications?
Thanks in advance!
Old 09-13-08, 06:55 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
i dislike the falken tires for the most part, so I'll not say much, but torque value should be same as stock, which I believe is 76 ft-lb
Old 09-16-08, 09:25 PM
Mesca
Mesca's Avatar
I thought we were supposed to torque it higher because the OEM Lexus lugs were efficient? It was something like 100% seated on the studs?
Old 09-16-08, 09:50 PM
mitsuguy
mitsuguy's Avatar
No, torque number is derived from how much pressure is needed to hold the rotor in place evenly and the maximum pressure the stud itself is designed to take...
TominBoise
05-28-19 01:54 PM
dappy
04-16-17 03:09 PM
silversx
07-12-08 03:52 AM
Briankim79
Hybrid Technology
05-01-08 06:14 AM
lawman
01-24-03 07:41 PM
Quick Reply: Got a couple questions..
