Spacers from IS350/GS350
Yes I sold my set of Ichiba from my IS350 to a local member that has the SC400. Its the same bolt pattern. I know he tool my 20mm spacer and put it up front and it was flush with the rim he was running. I am not sure what size you need but the answer is yes they are all the same. If you go 15mm or more they have bolt on kits so you can take it on/off very easy with out changing the studs. Ichiba Type II are the ones I had. I believe its www.Ichibausa.com
g/l
g/l
niebla
01-03-11 09:06 PM
Zeus69
11-07-08 10:03 AM
