Proper tire pressure for 20" tires - Nito 555's ZR
Old 12-04-08, 11:40 AM
Rezaxxed
Rezaxxed's Avatar
Default Proper tire pressure for 20" tires - Nito 555's ZR
Currently have a set of Nitto 555's ZR on my Work Rezax wheels. Here is my set up: 245/35/20 (20X9) Front & 265/35/20 (20X10)Rears. What is the proper tire pressure for all four corners. I would like to know what tire pressure other members are running on here. Your help is much appreciated.
Old 12-04-08, 03:54 PM
handoverfi
handoverfi's Avatar
just look on the tires it should say what the proper PSI rating should be!!
Old 12-04-08, 04:09 PM
Kyle Harty
Kyle Harty's Avatar
I've always kept about 38 psi cold in mine. Most people seem to run between 35-40.
Old 12-04-08, 04:56 PM
Indio
Indio's Avatar
40 psi is where you should be.
Old 12-04-08, 05:13 PM
rominl
exclusive matchup
rominl's Avatar
around 38 is where i'd set them
Old 12-04-08, 06:38 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Thats actually the MAXIMUM ALLOWED PSI... recommended PSI should be on the drivers door jam.
Old 12-04-08, 10:17 PM
Mesca
Mesca's Avatar
If your tire's have XL on them which indicates extra load (which yours do) you should have them around 40. http://www.tirerack.com/tires/tiretech/tirespecskey.jsp
Old 12-15-08, 01:36 PM
Rezaxxed
Rezaxxed's Avatar
Well, I spoke to Brandon who is the sponsor here: "You should use the recommended inflation pressures on the inside of the door jam, you may want to bump them up from that 2-3 psi."
My problem is, my door jam sticker is completely faded so I have no way of knowing what the stock recommended psi. I'm at about 35 psi right now.
Old 12-15-08, 02:17 PM
rominl
exclusive matchup
rominl's Avatar
stock lexus they are all 32-33psi (at least the passenger cars)
Old 12-15-08, 05:26 PM
GS300Rich
GS300Rich's Avatar
I would keep the low profile tires at 38psi OEM I kept at 32psi
Old 12-15-08, 10:12 PM
I8ABMR
I8ABMR's Avatar
Higher psi will avoid dents and will give you more even wear if the car is dropped. I am ususlly at 42 psi. The shop that does my wheels prefers 45 psi. Seems a little crazy so I just leave it at 42
y2tony3
03-12-16 10:43 AM
hube
09-26-15 11:17 PM
BenL
01-31-10 12:06 PM
Ozzy
04-01-08 07:06 PM
flossn
04-04-05 12:17 AM
Quick Reply: Proper tire pressure for 20" tires - Nito 555's ZR
