Tire recommendation...
Old 01-08-09, 05:52 PM
ecstaticSC
ecstaticSC's Avatar
Default Tire recommendation...
Can I get some recommendations on tire sizes for my wheel setup?
I have 17x9.5 +15 all around and my car is lowered close to 2". I was thinking of going with a Federal 595 tire- 235/40 on the front and 255/40 in the rear. How does this tire setup sound? This is for a SC300.
Old 01-13-09, 10:20 PM
ecstaticSC
ecstaticSC's Avatar
I'll rephrase the question.
How does 235/40-F and 255/40-R play in relation to tire height? Is this an ideal set up?
Old 01-13-09, 11:38 PM
Mesca
Mesca's Avatar
235/40 and 245/40 is almost identical. 245/40 is only 4 mm taller than the other one. If you were running the same width rim I'd just match all 4 together. Keeps all the tires running the same and you'll be able to rotate them too.
Old 01-14-09, 10:40 AM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
In the first post you said 255/40 do you mean 255?
Old 01-14-09, 04:15 PM
ecstaticSC
ecstaticSC's Avatar
whoops! Yea I meant 255/40 for the rear and 235/40 for the front.
Old 01-16-09, 02:29 PM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
235/45 and 265/40 are the best sizes to run on that vehicle but your wheel offset is kinda low.
Old 01-16-09, 05:31 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
if I had that car and some normal offset 17" wheels, I'd be runnin 255/40-17 and 285/40-17
but it's obvious not everyone wants a wide tire...
Old 03-30-09, 08:47 AM
ecstaticSC
ecstaticSC's Avatar
So, what would happen if I ran a 235/40 and 255/40? The speedometer would be thrown off?
Old 03-30-09, 04:30 PM
mitsuguy
mitsuguy's Avatar
yes, and there is a possibility the ABS and/or traction control if so equipped could have some problems... mine (ABS only) has had no adverse effects with the slight difference in front to rear tire diameters... OE tire diameter is 25.74" 255/40-17 is 25.03"
your speedometer will be 3% fast... you will be travelling 3% slower than your speedometer indicates... this is pretty damn negligible really...
Old 03-30-09, 09:29 PM
ecstaticSC
ecstaticSC's Avatar
Well I don't want to throw off my speedometer by 3%, so how about 235/45 and 245/40?
Old 03-30-09, 09:42 PM
mitsuguy
mitsuguy's Avatar
The only 17" sizes I can think of off top of my head that are the same diameter as stock (with .1") are 245/45-17, 275/40-17 and 225/50-17
245/40 is shorter than 255/40, so its for sure a no go for you...
235/45-17 is 25.33" diameter, so it would only be 1.5% difference...
Farino81
SC- 1st Gen (1992-2000)
09-21-11 10:05 PM
ecstaticSC
08-31-08 12:23 PM
Gvr4
05-27-08 07:08 AM
itssr20
04-09-07 08:26 PM
persian451
07-24-03 04:59 PM
Quick Reply: Tire recommendation...
