255'S on RX400H?
Can anyone tell me if 255's can be run on the RX400H? Will the rub when turned all the way in one direction? What about affect on the warranty? Thanks for any help.
I know an 18x8 with a 30mm offset works with 255/55-18's. If you plan to run the 255's on your OE wheels (18x7 35ET), they should work. the 255's will sit about 10mm closer to the suspension and will also stick out 10mm further towards the fender (mathematically).
Dallasguy1
05-16-16 09:22 AM
jessels4
18
01-28-08 12:21 PM
