zauber wheels
#32
Originally posted by gs4will
peter- thanks
hey Tiny....my "wheel bible" are the same as shown on Zauber site....
do you think 19x8.5 +36 high disk would work too?
thanks
peter- thanks
thanks
#33
I had a 18x8.5 with a Kuhmo 245/40 with a +31 offset on the front of the ride. It stuck out well past the outer edge of the fender. I bet some of the other 245's out there are meatier than the Kuhmo also. I would say that it stuck out about 4-5mm. Soooo....youd be REALLY pushing it with +36. I would think that there may be some rub too.
Ryan
Ryan
#34
Ryan
Ryan
Its the oposite....aggs400
I'd stay above a 38+ unless you get an 8.5 or smaller width
#35
No....I meant that the +31 was completely unacceptable to me and the +36 would sit right underneath the edge of the fender...too close in my book.
Thanx.
#36
peter- thanks
thanks
peter- thanks
thanks
Yes, i think it will be fine. +36 is as low as I would run on that car.
#42
So are the rears 9.5 or 10"???????????????
You say 9.5", Will said 10"....heeheeheehee
Congrats man!!! Just wait, this wheel has ALOT more going for it in person than in pictures....You will like them even more!!!
#43
I'll let you know how I like them, but they look SWWWWEEEEETTTT in your pics so I can only imagine.
Take it easy.
Ryan
#44
I went with the 9.5" I really didn't want to mod the fender with the car being pretty new. I could have done the 10" with a 275 but I like the square look. I think the 9.5 will still look pretty aggressive and have hella lip. Went with the +43 in front. I hope that is going to fill the wheel well enough. It looks good enough in your pics. Do you wish you had done the +36?
Take it easy.
Ryan
Take it easy.
Ryan
On the rear, 9.5" or 10" is fine...Its just the tire cant exceed a 275 using the +41 offset. Is the 9.5" a +41 also???
#45
Whew.
Thanks for putting me at ease. I like an aggressive fit but I do not care for the Japanese "let's put a huge wheel and a skinny tire to roll up under the fender so it fits sorta look".![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I also heard the Potenzas are on the wide side as well.
For rear, the 9.5" is also a +41. If I used the 285 tire, in theory, it would still rub. The 275 is only going to come in 5 mm from what you have leaving about 3 mm of clearance without mod. I think it will look tough...esp compared to the stock sunken in look.
Thanks for all your help Tiny...esp since I am getting the same wheel.
Hopefully it won't turn into another Dronell!
FYI...I heard U.S. retail on these is $3600!!!! Grey-market rules!
Take it easy.
Ryan
Angelina Jolie has nothin on Zauber!!
Take it easy.
Ryan
