My friend is selling his rims off a 350Z... I was wondering if they would fit an IS350. They are XXR 006's 19x8.5 front 19x9.5 rear offset is 33 in the front and 35 in the back. I have no idea what the tire sizes are, but only that the tires are Falken FK452s. Sorry but I'm a noob when it comes to fitment. Thanks in advance.
My friend says the fronts are 235/35zr19 and the backs are 265/30zr19's. They come with Motegi lugs... How much do hubrings usually cost?
Hubcentric rings are pretty cheap. You can pick a set up on-line for around $15.00. You'll need to locate the hub bore on the Motegi wheel which should be stamped somewhere on the back. The hub bore on the IS350, as you may know, is 60.1mm.
As far as the current tires go, you'll need to replace the rear 265/30-19 size. The IS350 needs to maintain a staggered tire height of at least 1/2" front to rear.
