Last edit by: IB Advertising
Browse all: Tires and Wheels Guide
- How to Fix a Tire Leak
Step by step instructions for do-it-yourself repairs
leaking tire bead
I have a leak in one of my tires and after dunking it, determined the leak to be coming from the tire bead. No work has been done on my wheels or tires since I purchased the tires back in July. I didn't hit a pot hole lately and the rim doesn't look bent in that area. Does anyone know what would cause the bead to suddenly start leaking? Also, any fix for it? Would simply re-seating the tire fix it? I heard using bead sealant is just a temporary fix too... is that correct? What should I do?
interesting... most of the time, when that happens, its because its chrome, or the tire is damaged...
the only way to know truly what is going on is to take it to a tire shop and have the bead popped off the wheel for inspection... depending on the wheel, you can sometimes do this at home just by deflating the tire, but you probably won't get it reinflated with just a normal air compressor - getting the bead of the tire to seat again is quite hard without a large volume of air...
either way, you need to check it out - it might be a torn bead that is just finally showing up, or who knows... clean it, bead seal it, be done with it... bead sealer is not a fix all, but it should work in this situation... because your tires are stretched, you might have a little bit of corrosion going on in there... (not stretched tires don't really let the water sit in there at all)
I have had problems the last month with my tires leaking around the rims. I have a Lexus GS300 (2006) and had new tires put on about a year ago. The tires are an Avenger touring LSR SL BW 94V TL, if that helps. The place that I bought the tires from said it's the metal rim causing the problem. Any ideas??? It's happened 3 times now, the last time on a long trip to FL. It seems to happen when they get cold. (after sitting over night in the garage, or another time I had traveled 11 hours one day, and the next morning low tires.) ANy help would be greatly appreciated. I paid a bundle for these tires. I'd like to have piece of mind when I travel.
