What are these wheels?
Old 02-10-10, 07:59 AM
justinp95
justinp95's Avatar
Default What are these wheels?
What are these wheels? The owner says they are Wiclia but i dont think he knows english. They look to be Miclia and he said they are the "1000" model, but doesnt know anything about them. Im looking for the specs but i cant even find anything on the brand muchless what wheel specs are. They are 18s though. Thanks
Old 02-10-10, 09:22 AM
Spyder78
Spyder78's Avatar
Mille miglia emotion ssl
Old 02-10-10, 11:22 AM
justinp95
justinp95's Avatar
Its turns out they are 18x8, but i cant find the offset anywhere for them. Any know it or would have pics of them on a ls400?
Old 02-16-10, 01:38 PM
justinp95
justinp95's Avatar
tttttt ttt
Old 02-20-10, 02:32 AM
nolexhere
nolexhere's Avatar
Most likely in the high 40s so if you are looking for something flush your going to need to install spacers or get some different wheels.
Old 02-23-10, 10:33 AM
justinp95
justinp95's Avatar
so the higher the offset the more the wheel is pulled in?
Old 02-23-10, 04:43 PM
nolexhere
nolexhere's Avatar
Correct. If a 18x8 wheel has say +50 offset and another 18x8 wheel has +25 offset the 18x8 +25 wheel will sit out 25mm (1") more than the 18x8 +50 wheel.
Old 02-24-10, 11:04 AM
justinp95
justinp95's Avatar
Does anyone know on a 8" wide wheel what the minimum amount of offset is required to clear the 99 LS400 brakes is?
Old 02-24-10, 04:31 PM
nolexhere
nolexhere's Avatar
I have seen people run g35 wheels which are 8" have around a +30 offset but I can't say for sure if yours will work. You could always just bolt one on real quick and check.
Old 03-17-10, 07:22 PM
justinp95
justinp95's Avatar
If they were 18x8 with +35 offset that should clear the calipers correct?
Old 03-18-10, 02:50 AM
angus
angus's Avatar
The offset really has little to do with caliper clearance , every wheel has a different spoke profile and curvature so clearance varies by design, not offset.
Old 03-18-10, 07:46 AM
justinp95
justinp95's Avatar
Hmmm true. These look like they curve out so they look like they may work.
jodo
IS F (2008-2014)
11-04-12 10:27 AM
speeds27
11-02-10 05:38 PM
tarponman
09-30-09 07:03 AM
TexasGS
10-06-05 01:35 PM
jamecl
04-17-01 04:38 PM
Quick Reply: What are these wheels?
