PS2 tire bubble/crack
Was about to get in the car to return home when I happened to look down at my wheel and noticed this:
![](http://i444.photobucket.com/albums/qq169/giantsfan7490/Lexus/DSC_0636.jpg)
![](http://i444.photobucket.com/albums/qq169/giantsfan7490/Lexus/DSC_0634.jpg)
I have not hit the curb/etc ... so I don't know what could have caused this.
Was thinking about calling tire rack, but wanted to check with you guys to see if its really a big problem or not.
Thanks
Thanks
Yeah ... I did hit a pothole yesterday - in the middle of the freeway
By the time I saw it it was too late to change lanes, too many cars around me. Glad to know mine is not too bad.... but is it still safe to drive on? (I do see metal braided things if I look into the hole.... )
Would this stuff be covered under warranty?
As for my tread, its actually very good.... its just the angle.
![](http://i444.photobucket.com/albums/qq169/giantsfan7490/3cfca24b.jpg)
Super Moderator
Potholes are by far the most frequent cause of sidewall bubbles. The lower the aspect ratio of the tire, the easier it is to cause this type of damage. It's a dangerous condition - replace the tire before you have a blowout.
It would be covered by optional road hazard protection (if you bought it), not by the warranty.
Received 1,064 Likes
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
I had a tire bubble pop at a gas station.. after an 1hr fwy drive... (on my IS300).
It could have easily popped during the drive.
Joe Z
I would get it replaced prior to that...
I have seen people go for months like that... at the same time, I have had customers that have had amazing blowouts with that same type of damage...
there is no metal in the sidewall...
what has happened is that the cords that run radially out from the wheel have been broken... the cords are made out of the same thing clothing is, typically polyester or nylon... probably only a few right now... but what happens is that puts stress on the cords near to them, and eventually we have a failure that we nicknamed the zipper failure... essentially its like a zipper opening up radiating out from that bubble... it can be dramatic, or it can just open up and fail... neither way do you want to be driving when such failure occurs...
do you see that clean, shiny part of the wheel right where the bubble is... that is clean because the tire was pinched up against it when you hit a pothole or similar...
Thanks, guess ill be driving the back-up car for a few weeks.
Now for replacing the tire, It should be fine replacing just that one, right? Would it be a problem if the drivers front has a new tire while the passenger front has an semi-new tire? (The tires are 7 months old at the moment - roughly 5k on the tires - pic of tread above)....
