2008 RX350 Tires
2008 RX350 Tires
My wifes 2008 RX350 has about 3/32 left of tread (28,000 miles on the OEM michelin energys).
I would like a new tire that lasts longer and performs better, any suggestion I see the conti extremecontact and bridgestone deuler alenza get great reviews.
Also has anyone moved up in size (wider) on the OEM wheel? I did this on her last RX so I could get different tires (more options)
Thanks
E
Thanks
E
In the OE size, I suggest looking into the Goodyear Assurance Fuel Max and Hankook Ventus A/S RH07. Both models carry a 65K mile tread life warranty with great ride quality and all-season traction.
- thanks unfortunately the fuel max are not available in my OEM size only the assurance comfort treat and the fortera triple tred
If you are not happy with the mileage out of your current size tires, I don't believe you should go larger or wider since the mileage generally goes down with larger tires. Besides the ride may likely get firmer and not to mention that may screw up your factory GPS readings if you have one.
