n00b question, rim/tire fitment
Old 06-08-10, 07:26 PM
Asakura58
Asakura58's Avatar
Default n00b question, rim/tire fitment
Hello all.!
n00b question... I have an is250 awd, and I am looking for some rims+tires..for rims what offset, size would fit same goes with tires.. any help much appreciated!~
tired search function and no luck...
thanks in advance!
Old 06-14-10, 09:24 AM
Sltwtrking
Sltwtrking's Avatar
You can run up to 20" wheels and tires very easily on your IS. Did you have a diameter in mind?
Old 06-17-10, 04:03 PM
Asakura58
Asakura58's Avatar
^ thanks for the reply good sir..
would thses fit my awd
Boss Rims 5 x 114.3 20"
Tires 245/35 ZR20
Old 06-17-10, 05:59 PM
Sltwtrking
Sltwtrking's Avatar
The tire size is too tall IMO for your application. Depending on the width and offset on the wheel, I would consider either tire size 225/35-20 of 245/30-20.
What is the offset and width on the Boss wheels you are looking at?
Old 06-17-10, 06:12 PM
Asakura58
Asakura58's Avatar
^hmm offset and width..idk but ill ask for it...
what about this:
20" Ace Executive rims
5x114.3
Front
20X8.5 OFFSET 35
452 225/35/20
Rear
20X10 OFFSET 40
275/30/20
would theses bad boys fit?
thanks again! +1 rep for you for help
Old 06-17-10, 07:04 PM
Sltwtrking
Sltwtrking's Avatar
what about this:
5x114.3
Front
20X8.5 OFFSET 35
452 225/35/20
Rear
20X10 OFFSET 40
275/30/20
The 8.5 +35 will certainly work but you should not stagger your tires since your vehicle is AWD. I suggest running tire size 225/35-20 with those wheels and on all four corners.
Old 06-18-10, 10:41 AM
msgs350
msgs350's Avatar
Staggered is OK...but get 235/35 fronts and 275/30 rear.
Old 06-18-10, 08:51 PM
Asakura58
Asakura58's Avatar
i take it the current setup on the Ace rims ideally wont work?
And the offset for the boss rims is +38mm offset and 8.5 width. Will that work with its current tires and all, without any rubbing or what not..
Boss Rims 5 x 114.3 size:20"
Tires 245/35 ZR20
Also on 20" rims how many click would I get.. now I get 416KM ish (260 miles) on a full tank of gas..what will my fuel drop to? IF there even is a drop :S
Old 06-19-10, 01:26 PM
Sltwtrking
Sltwtrking's Avatar
You can run the ACE wheels I just don't recommend the staggered setup. The 20x8.5 +35 or +38 will work on all four corners. I would not go with the 245/35-20 tire size as it's 1.75" taller in rolling diameter which can have an affect on your ABS/Traction control. Go with 245/30-20 or 225/35-20 just be aware that the 245 is the widest you can go without having to make fender mods/running neg. camber.
Old 06-23-10, 10:35 AM
Asakura58
Asakura58's Avatar
how about this setup
18x7.5 and 5x114 bolt pattern.
offset +42
Tires: 225/40ZR18
Will this work the way it is on my awd?
ty
Old 06-23-10, 11:05 AM
Sltwtrking
Sltwtrking's Avatar
That setup will work just fine
Old 06-23-10, 11:34 AM
Asakura58
Asakura58's Avatar
^ sweet! Gonna contact seller of those rims asap then! Thanks Sltwtrking thus far you have been the best help! too bad there is no +rep feature on the forums!
Old 06-23-10, 11:55 AM
Sltwtrking
Sltwtrking's Avatar
No sweat glad to help.
Old 06-23-10, 10:57 PM
Asakura58
Asakura58's Avatar
^ how u think theses will look on my GFM is250 could get theses for roughly 6 bills with rubber 50% remaining... size is the 18"
Old 06-24-10, 12:59 PM
Sltwtrking
Sltwtrking's Avatar
I think they'll look pretty good. The only thing I don't like about the new 18" set-up is that the wheels will sit in the exact location as your factory wheels. I like packages that are almost flush with the fenders.
Quick Reply: n00b question, rim/tire fitment
