rim dimensions
i hav a 2001 black gs300..i wanted 2 get 20" rims and was wondering what kind of dimensions should i get for the front and the back..i dont have a clue about that and any info would really help..thanks in advance
20" x 8.5" +38 to +45 with a 245/35-20 tire...
If you want to stagger the rear (meaning = have wider wheels in the back since it's a rear wheel drive [RWD] car), you can do a 20" x 9.5" +37 to +45 or even a 20" x 10" +43 or so with a 275/35-20
This will give you a setup where you won't need to roll the fender or do any other type of modifcations...you will rub the INNER fender a little bit but that's due to the oversizing on the tires versus stock...no big deal, it will rub for a little bit then it will eventually stop. Doesn't hurt anything I assure you...
Also, this topic has been covered about 10 ZILLION times so it would help if used the SEARCH function and read some of the past posts.
