Will these 19" wheels work on a SC?
Old 07-04-02, 11:59 AM
AutoCoutureSC
AutoCoutureSC's Avatar
Post for any of you wheel experts out there....
would this fit on a SC400?
19 x 9 front
19 x 9.5 rear
would this combination work without rubbing? These rims came of a GS400. Thanks... for everything!
Old 07-04-02, 02:15 PM
Wheel Experts
Wheel Experts's Avatar
More than likely, it would be OK if it came off a GS, but specific offsets and tire sizes would be needed to see if it rubs or not. That's really not enough info.
Old 07-05-02, 12:08 AM
AutoCoutureSC
Post
Fronts- 245/35/R19 (9")
Rears- 275/30/R19 (9 1/2")
my SC is lowered 1" w/ eibachs.
Old 07-05-02, 10:06 AM
AutoCoutureSC
Old 07-11-02, 07:34 PM
AutoCoutureSC
nobody knows???
Old 07-11-02, 07:39 PM
AutoCoutureSC
Post anybody know any info about this?
I'm not getting ANY answers for this in the wheels forum, so moderators, please do not move this thread.
Would a these fit on a SC400? These rims came off a 99' GS400
19 x 9 .....245-35-19
19 x 9.5 .....275-30-19
I'm thinking about buying these rims, but i need to know for sure if they'll fit without rubbing. I have lowered my car with eibachs if that will help. I know Chairmanoftheboard put 18 x 10 on the rear, but the 275-10-19 tire might be too far out. Anyone with any knowledge?
Oh, I tried the search feature and have not come up with anything. thanks!
Old 07-11-02, 07:46 PM
pcmw
pcmw's Avatar
Well Doluck,
You need to find out/give out more specific info. Like what is the offset of each wheel, what brakes you have, do you have a 100lb speaker box in the trunk, etc.
I would think that a 9" wheel in the front is a bit wide, but the 245 tire is pretty narrow.
Later
MW
Old 07-11-02, 07:49 PM
AutoCoutureSC
finally, a reply. the guy just said that the offset is correct for a gs400. that's all the info i have. darn it!
i have stock brakes, and only 2 amps in the trunk.
Old 07-11-02, 08:02 PM
pcmw
pcmw's Avatar
Well, my guess is that at 9" fronts (which are the only ones that may not fit) you would need a minimum of ET40-45 offset to be able to stay under the fender. The rears should fit if they fit on his GS.
Before putting down that much cash...get ALL of the info.
Later
Old 07-11-02, 10:53 PM
Manaray
Manaray's Avatar
Well if it worked on a GS, then it should work fine on a SC...did they GS guy ever roll his fenders though? Also, a lot of times the offset is stamped on the backside of the wheel (usually on a spoke)...
Old 07-12-02, 01:32 AM
1BomexLex
1BomexLex's Avatar
ive heard 19s will fit alright...
cause you can get really wide in the rear...its just the front you need to worry about .. i think
just cause the front is the only ones taht turn
Old 07-12-02, 09:04 AM
SoCalSC4
SoCalSC4's Avatar
Typically, a 9" wide wheel will need to be +35 to +40 to fit properly on the front of an SC- any higher offset than +40 will hit the suspension upright, any lower than about +35 will stick out past the fender.
I built 19x9 +35 for my personal SC- just waiting on tires. There's a photo on the board somewhere of an Auto Couture SC400 with 20x9 +36: this sits nice & aggressively, but does not stick out of the fender.
I'd say is the 19x9s came off of a GS, they'll fit your SC just fine- dimensionally, the cars are very similar under the front fenders.
Old 07-12-02, 01:58 PM
AutoCoutureSC
wow! thanks for all the info! i love this board... but i'll find out offsets today hopefully. i hope he tells the truth.
Old 07-13-02, 11:10 AM
howiedoit
howiedoit's Avatar
hey...what kind of wheels are they?
Old 07-13-02, 07:47 PM
AutoCoutureSC
Post
I just got the offset. it's
19 x 9 w/ 245/35/19 43 offset
19 x 9.5 w/ 275/30/19 44 offset
so what do you guys think? howie, they're m5's.
Quick Reply: Will these 19" wheels work on a SC?
