Brushed aluminium - how to refinish
Old 08-23-10, 08:29 AM
koksik
koksik's Avatar
Default Brushed aluminium - how to refinish
I have some question. I just bought a new rims for my car and center face of rim is in brushed aluminium effect. In some places there is some of corrosion on (clear?) coat and I'm wondering how I can refinish my rims.
Any suggestion?
thanks
Old 08-24-10, 01:16 PM
VIPG35
VIPG35's Avatar
1. Get paint stripper and remove all the old clear with a plastic scraper.
2. Wash the wheel with dish detergent soap and dry.
3. If there is still corrosion get some mothers aluminum polish and rub the spot and wipe off. (if the corrosion is too deep get some 220 grit and sand in the same direction the original brushed finish pattern)
4. Use wax and grease remover.
5. Spray some Adhesion promotor (clear primer)
6. Spray clear coat
Some basic steps i use hope it helps you out.
Old 08-24-10, 03:52 PM
koksik
koksik's Avatar
Thanks for reply. Where I can get clear primer? First time I heard about primer like that. So if I remove only clear coat, and clean wheel I still keep brushed aluminium effect ? ( I mean without extra sanding )
And whats mothers aluminium polish ? Is that metal polishing paste ( like meguiar's aluminium polish? )
Old 08-24-10, 04:06 PM
VIPG35
VIPG35's Avatar
You can get it at your local auto parts store, autozone, advance auto, oriley's and walmart. If not you can always buy it online here: http://www.amazon.com/ADHESION-PROMO...2690768&sr=8-1
Yes the brushed effect will still be there. I know this because i had some trafficstars rts diamond cut finish and the rim shop's impact gun hit the face causing the clear coat to have a crack. So all i did was stripped off the clear on the cracked area and spot blend painted it, sand, and buffed. The results were perfect like nothing happened. Yes its the same polish it just to remove acid rain corrosion with out the use of sanding. If you need any other tips let me know.
Old 08-24-10, 04:16 PM
koksik
koksik's Avatar
pm send, and thanks again!
jbwilmoth
RC F (2015-present)
08-05-16 04:54 PM
Rich27
12-25-08 06:18 PM
350vibez
09-10-07 12:59 PM
thirdmotio
Automotive Care & Detailing
04-11-05 09:42 PM
Lex2Go
02-11-05 08:26 PM
Quick Reply: Brushed aluminium - how to refinish
