Tire Rack guys, please help me!
Old 09-12-10, 05:34 PM
Mike552
Mike552's Avatar
Default Tire Rack guys, please help me!
I am a regular tirerack customer, but this time I am asking about a used set of wheels in the hopes that you can help me out. I am looking to purchase a set of 20" Platinum Apex wheels, which I am pretty sure came from you guys... I am trying to get the offset, but all the numbers stamped on the rim give me no indication of what it is. Maybe you can decipher this?
T-200 20X81/2 JJ
TL 1017 DOT-T
20 07 07 A2 A2
QC-E
SAE J2530
ET UW
Thanks!
Old 09-13-10, 05:41 AM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
The number after ET is the offset are you sure your reading it correctly?
Old 09-16-10, 09:45 AM
Sltwtrking
Sltwtrking's Avatar
The 20x8.5" Apex was only produced with two offset choices which were +40mm or +43mm. Assuming your PCD (bolt pattern) is 5-114.3 (5-4.5") then the offset on your wheels is +40mm.
Reference: http://www.ultrawheel.com/pdf/rims/2...ack%20FWD2.pdf
Old 09-16-10, 12:48 PM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
If it is a 40 then this should be stamped on the back of the wheel...
"Et40/20x8.5JJ/SAE"
UnholyAres
SC- 1st Gen (1992-2000)
12-10-12 12:13 PM
Scythe
03-12-08 11:38 AM
Alexus-Kia
07-09-04 09:29 AM
big bad furby
09-17-02 09:20 PM
Quick Reply: Tire Rack guys, please help me!
