Noob IS wheel question...
Old 12-17-10, 09:50 AM
-Samurai-
-Samurai-'s Avatar
Default Noob IS wheel question...
Ok guys really noob question but I cant find them anywhere! I know the first and second generation IS had 17" OEM wheels in a couple different styles BUT apparently there's an 18" OEM IS wheel? Not sure from what years or anything but what the heck does it look like? Pics would be awesome!
Old 12-17-10, 10:03 AM
-Samurai-
-Samurai-'s Avatar
Ok are these 18's? I always thought they were 17's?
http://www.1010tires.com/images/whee...s_is250_lg.jpg
rominl
exclusive matchup
rominl's Avatar
1is only had one 17s, i didn't know they had different styles
2is, 17s are standard, and 18s are options. most of the 2is out there i believe have 18s now. 2is are from 06+. just look at most of the factory 2is pics and they have 18s
Old 12-17-10, 10:12 AM
-Samurai-
-Samurai-'s Avatar
Ok thanks for the reply. I always thought they were 17's, then I saw 18's on a site that were factory IS 18's but no picture so im like, umm what? So just wanted to make sure they were legit. Thanks again!
Old 12-17-10, 12:39 PM
IXI187IXI
IXI187IXI's Avatar
the ones you posted are 18s
see here
Old 12-17-10, 07:31 PM
-Samurai-
-Samurai-'s Avatar
see here
THanks bro, just bought a set of those lol
Old 12-17-10, 09:12 PM
-Samurai-
-Samurai-'s Avatar
Well mind as well ask this in the same post. Whats the best tire size to put on these wheels. 18 X 8 and stock ride height? I was thinking 225/45?
Old 12-20-10, 10:28 AM
-Samurai-
-Samurai-'s Avatar
Bump......
Old 01-07-11, 03:15 AM
dsp979
dsp979's Avatar
1IS had 2 17 inch wheels, the 5-spoke (most common) and the 11-spoke Sport Design rim.
Old 01-07-11, 12:07 PM
Jetfire
Royale with cheese
Jetfire's Avatar
the stock sc400 is 225/50/16. so in order to get the overall diameter close as possible. you can run 225/45/18, 245/40/18, etc
just plug in your stock size. then compare the new wheel size. as long as it's within 3% diameter you'll be fine.
http://www.miata.net/garage/tirecalc.html
do you want a higher sidewall with skinnier tire or beefy tires and low profile? any plans to lower?
Old 01-07-11, 12:54 PM
rominl
exclusive matchup
rominl's Avatar
you are right, totally forgot about the SD wheels
Old 01-31-11, 12:04 AM
-Samurai-
-Samurai-'s Avatar
Woah thanks man, this came in handy!
Jake88
05-31-12 11:48 PM
frantinez
10-11-09 12:19 AM
LS430_Mike
05-08-09 07:08 PM
slw ls1
GS - 1st Gen (1993-1997)
02-22-08 11:05 PM
OneOfOne
02-08-06 08:43 AM
Quick Reply: Noob IS wheel question...
