stretching tires with fire!!!
Old 05-15-11, 08:02 PM
  #31
the.wong.k
the.wong.k's Avatar
Originally Posted by Kohinoor
this is nothing new. this method has been used for decades.
+1 it's not a recommended method (due to possible bodily harm to you or others) but rarely does it have problems.
Old 05-15-11, 10:02 PM
  #32
JDMmuscle
JDMmuscle's Avatar
this is how I have to get my tires on. Supply Air, Spray Ether, Light on fire, Prosper
Old 05-15-11, 10:08 PM
  #33
JDMmuscle
JDMmuscle's Avatar
Originally Posted by MIGS
Get Mad.
lol
235 on 12" incher
Old 05-15-11, 10:27 PM
  #34
BAD954BOI
BAD954BOI's Avatar
wow!!!
this really caught me off guard that was a good video!!
Old 05-15-11, 10:40 PM
  #35
scottys209
scottys209's Avatar
Originally Posted by Klaus
This isn't about running "meaty" tires- I'm not saying every car needs it. If you want to run a 255 out back, cool just don't exceed 10" on your wheel, 9.5" ideally. There's a GOOD reason why no reputable tire shop is going to do this for you. Any comparison to drift cars is absurd as well as we're talking about streets cars here, nothing more, nothing less.
There's no convincing needed. The manufacturer has already specified the safe range of wheel sizes for their tires, so anything else by definition is wrong. You wouldn't put h rated tires on a car you're going to do 180+ in either
Preaching to the choir bro, I've waxed lyrical about this.... However I realize it won't change a thing, so by helping to give tips on how to do this properly and keep the arguements low, members will at least be safer when they try this method of mounting tires for the first time.
Old 05-16-11, 06:53 AM
  #36
PeteSoarer
PeteSoarer's Avatar
I think this method harms less the wheel than normal wheel machines, which may cause scratchs and marks to wheel. Just balance the wheel/tire after you have "popped" if its necessary.
BTW can this be done with normal tire sizes(non stretch)? like 9.5" wheel + 265/40 tire.
Old 05-16-11, 07:49 AM
  #37
RedPhoenix
RedPhoenix's Avatar
Done it before haha... Popped a bead on my rear by letting it go flat. Easy peasy.
Old 05-16-11, 07:56 AM
  #38
TechGreek
TechGreek's Avatar
Tell that to a buddy who totalled his 94 RX-7 running a 235 on a 10.5" wheel who had his beat unseat at 70 going around what I would consider a gentle curve (maybe 30-40* of steering angle?) where his tire was almost instantly destroyed flinging rubber into traffic damaging other cars and causing him to slide into another vehicle totaling both cars. The insurance companies were throwing around lawsuits left and right and thank god he had enough liability coverage to cover all the damage (total was over 100K). Was the tire shop liable? That's still going on...
Lesson is cut this garbage out on street cars
235 Wide on a 10.5 is too wide imo... I have 235 on my rear 10 and it's pushing it for me.
I haven't had an issue personally except when the tires wore down to bare they would lose air pressure then I let it get to low and it unseated the bead in the driveway.
Off-road guys do this with huge tires when they are out and about so they can reseat the tires (big tires and small wheels, it happens too). I've also seen drag racers do this with drag slicks on the track.
I wouldn't personally do it.
Old 05-16-11, 08:18 AM
  #39
Biggu
Biggu's Avatar
I do it all the time in the garage when a tire doesent want to mount. easy as can be.
Old 05-16-11, 09:20 AM
  #40
BartleDoo
BartleDoo's Avatar
Originally Posted by lookEVO
I even had a gti that i put 165's on a 10 inch rim and drove it for 2 years.
I have to call BS unless you post photos. That is considered cool in the VW world???!
Old 05-16-11, 10:32 AM
  #41
LukeNag
LukeNag's Avatar
WOW. Crazy
Old 05-16-11, 11:33 AM
  #42
Bender25
Bender25's Avatar
Originally Posted by JDMmuscle
lol
235 on 12" incher
Damn those tires must run big, they look way bigger than my 255 on my 12"-
Old 05-25-11, 11:44 AM
  #43
j three
j three's Avatar
Looks like they have taller sidewalls.
Old 05-25-11, 04:45 PM
  #44
IS-SV
IS-SV's Avatar
Entertainment value at least.
Old 05-25-11, 06:10 PM
  #45
is350memb
is350memb's Avatar
sweeeeeeetttt stretched tires. look really great and i am tempted to do this too
Quick Reply: stretching tires with fire!!!
