18×11.5 +5 18×13 +0 5×114.3 Fit Ls 400???
Depends on your definition of "fit" There are LS's out there with those size wheels on them, but they are either wide body or have had the fenders severely modified...
on the front, 9" is about as wide as you can expect to fit, and in the rear, probably 10 or 11" with stretched tires even...
Being stock height, it will poke though the main issue would be the front caliper clearance. If you lower then you'll have the pulling, shaving/rolling and probably some camber plates done up. With that aggressive a stance, you will not be looking to get 10K miles out of the tires. ![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
GSLEX0586
01-31-12 02:25 PM
BNR34
12-10-06 11:25 PM
