Staggered Tire Sizes
I'm about to put new wheels on my SC430. 8.5x20+25 in front and 9.5x20+25 rear.
Another member had recommended 235/35/20 & 275/30/20 tire sizes. He said that mathematically that's a better match than if I ran 245/35/20 in the front.
Unfortunately, the tires I want (Continental DWS) only come in 245/35/20 in the front. All season tires would be a big plus since I get a little bit of snow here and this is my only car.
Will it cause any issues to run 245/35/20 in the front with 275/30/20 in the rear?
Thanks for the replies. I am worried about rubbing in the front. I had a set of wheels before in the same sizes with more conservative offsets (8.5x20+35 / 9.5x20+35). I had 235/35/20 in the front originally with no rubbing.
When I replaced my tires, I ordered the same size and had some rubbing on the front liners going over bumps, which I was fine with since it didn't get into the fender. I assumed it was rubbing because the new tires had more tread. Then later I realized they put the wrong size on (245/35/20). The more I think about it, I'm worried with the more aggressive offset it will get into the fender.
If that's the case, I may just go with the summer tires and get a set of winter tires to put on my stock wheels for winter. But we only get about 5 days of snow here, so that's a little excessive.
Also, here's a shot I took with my old wheels (8.5x20+35) with 235/35/20.
![](http://img220.imageshack.us/img220/3029/car6small.jpg)
I would agree it seems like a bit of a waste to have winter tires for that little time. I would play around with sizes you would like to run and see if you can find an all-season that will work or just park the car for those 5 days a year. I know there is a Michelin Pilot Sport A/S+ you could run 245/30R20 front and 255/30R20 rear and use your existing wheels?
![](http://www.tirerack.com/images/tires/michelin/mi_pilotsp_as_plus_ci2_l.jpg)
I was looking at the Continental DWS. The rears should be fine with 275. It's the fronts that I'm worried about rubbing the fender.
It doesn't look like anyone makes a good all season tire in 235. Hankook makes one, but it got very poor reviews for snow and ice, so it's probably not any better than a summer tire.
