noobie to wheels & need help on offset fitment
Old 09-22-11, 06:15 AM
Mike813
Mike813's Avatar
Default noobie to wheels & need help on offset fitment
I was interested in picking up a set of rims off a 2nd gen IS but was afraid the fitment would be too aggressive for my 2nd gen GS without any fender mods. for the pros out there can anyone give any guidance on how these might or might not fit. current mods on my suspension are only kyb & eibach which is roughly a 1.5 drop with 2 finger gap from wheel to fender. with no plans for fender modifications will i run into any issues? (rubbing, turn lock/lock, bumps)
the wheels that are being sold is off a IS below is the size.
20x9 + 38 and 20x10.5 +45mm. wrapped in 235/30/20 and 275/30/20
thanks for any information.
Old 09-22-11, 07:21 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
actually, that should look pretty nice... good chance it is going to rub though - rear fenders possibly, front fender liners... nothing that can't be fixed with rolling the fenders rear and trimming a little in the front...
it may fit just fine with that high of an offset - would be close...
Old 09-23-11, 01:06 PM
Mike813
Mike813's Avatar
thanks for the input . i was trying to avoid the fender modifications because the paints semi new still and dont want to repaint if it chips/cracks and all the horror stories ive heard with rolling/shaving.
you think it would rub though at my height level? 2 finger gap.
Old 09-27-11, 06:52 AM
mitsuguy
mitsuguy's Avatar
not all the time, obviously, but when you hit bumps, have passengers in the rear, hard turns, etc...
Old 09-30-11, 06:21 AM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
I'll be running 20x9 +32 and 20 x 10.5 +42 next week with 245 30 20 and 275 30 20.. I was told by a few people that i will have no issues at all.. I'm on coils so if i have to adjust i can... The lower offsets in the +15 to +25 is when i beleive you need to start trimming and moddifying.... I went through this same questions yesterday lol..
I think you'll be fine with no issues..
Old 09-30-11, 08:52 AM
zig@tr
Former Sponsor
zig@tr's Avatar
These size are my recommendation for that vehicle as well, with the offsets it doesn't appear to be a problem but it may take some tweaking on your part as far as the ride height and compression ratio of the coil-overs. The rear wheel may be the only issue as it is a little wider than I would recommend, but with very little modification you should be able to make this would.
Yesterday
SC- 1st Gen (1992-2000)
01-20-11 05:51 AM
olddog
02-04-09 01:18 PM
brianvan1
05-13-08 01:23 PM
Tank
03-29-07 04:51 PM
Gs L-tune
02-08-05 02:23 PM
Quick Reply: noobie to wheels & need help on offset fitment
