91 LS400 tire change
Old 09-30-02, 10:39 PM
kolofai
kolofai's Avatar
Default 91 LS400 tire change
The tires on my 91 LS400 are original tire 205x65x15 with only 37000KM on it but since they are 11 years old so I would like to change them all. I got mixed info that I should stick with original size if I want to keep the old wheels. Some said I can go wider such as 225x60x15. Which one is ture ? I just want a smooth ride so what is the best combination ?
The 2nd question I have is if I replaced the tire can I rotate the tire freely not just front and back like the orginal one but cross right ?
Old 10-01-02, 02:01 AM
strongsail
strongsail's Avatar
What's important is the outside diameter of the tire - it should be as close to stock as possible - next is wheel width, it's embossed on the lip of the oem wheel, probably 15x6.5 or something like that - I doubt if you would notice much difference in ride quality - try this link:
http://www.rx7turboturbo.com/robrobi...e_diameter.htm
SammyRed
01-30-14 08:58 PM
jdmsole06
02-13-08 07:14 AM
capper
14
06-17-02 11:14 AM
pongydoo
04-25-02 11:14 PM
Quick Reply: 91 LS400 tire change
