Do I need a new rim?
Old 10-08-11, 06:26 PM
airahcaz
airahcaz's Avatar
Default Do I need a new rim?
lower ball joint, I assume, gave way and car is sitting in mechanic shop till Monday.
It scraped the interior of the front left rim, and continued to do so as we drove it onto the tow truck and off.
Has the integrity of the rim/wheel been compromised significantly?
Attached Thumbnails Do I need a new rim?-2011-10-08-gs-ball-joint-breakdown-004-640x480-.jpg   Do I need a new rim?-2011-10-08-gs-ball-joint-breakdown-013-640x480-.jpg   Do I need a new rim?-2011-10-08-gs-ball-joint-breakdown-026-640x480-.jpg
Old 10-09-11, 12:55 PM
j three
j three's Avatar
That is a decent scrape! That is a stock rim and you should be able to find a replacement with no problem. Do that and you will be safe.
Old 10-09-11, 02:55 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
I agree, I wouldn't chance it...
Old 10-26-11, 06:59 AM
YviE
YviE's Avatar
I think you are ok, but have a tire shop look at it.
Old 10-26-11, 07:07 AM
mitsuguy
mitsuguy's Avatar
I work for a tire shop and I don't think he is OK...
would you chance a weakened wheel on the highway at 70+ mph? how about going round turns putting some real force on it...
Old 10-26-11, 07:12 AM
YviE
YviE's Avatar
Didn't know you work in a tire shop. So yeah, that is why I wrote "I think".
I have driven on wheels with similar damage and never had any issues (other than vibrations). *knock on wood*
Old 10-26-11, 07:26 AM
airahcaz
airahcaz's Avatar
I'm getting rid of the set altogther, haven't had a chance to take pics - I'm riding OEM 16's with Blizzaks already, and will look for 17's come springtime, or maybe even another set of 16's.
Old 11-01-11, 01:17 AM
soaring72
soaring72's Avatar
go find someone that tig welds aluminum, lay a bead over the scratch, file/grind/sand it down, go get it balanced, and put ur money back in ur pocket....
Old 11-01-11, 05:15 AM
mitsuguy
mitsuguy's Avatar
While I definitely agree that would be safe, unless a buddy does it, chances are it won't be much more money for a used wheel... You could also get some money back for the bad wheel sold as scrap...
opelmanz
RX - 1st Gen (1999-2003)
01-31-17 10:32 AM
BigJohnLs
CL of Southern California
12-29-10 03:32 PM
Kybball#1
12-18-10 03:07 PM
rjsix
Southwest
05-09-09 10:35 PM
ub2slow2
IS F (2008-2014)
17
08-05-08 12:10 AM
Quick Reply: Do I need a new rim?
