Michelin says to put 2 new tires on REAR... does that me I shouldn't rotate them?
Old 10-29-11, 04:50 PM
BlueCrabby
BlueCrabby's Avatar
Default Michelin says to put 2 new tires on REAR... does that me I shouldn't rotate them?
I had to order two new tires from Tire Rack because they were damaged.
The undamaged tires had only 10,000 miles, so I didn't want to waste money
getting a whole set of tires. The two new tires are identical to the old tires.
Michelin's website said I should have the new tires mounted on the REAR,
so that's what I had the tire shop do. It's supposed to be safer because
the new tires on the REAR will have better traction in rain.
It's been 5000 miles.... so I'm confused... should I now stop rotating the tires?
If I do, the newer tires will end up on the front, which is against what Michelin
recommends.
Any advice appreciated!
Old 10-29-11, 06:38 PM
chikoo
chikoo's Avatar
Lol. U should go ahead and rotate them.
Old 10-29-11, 08:00 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Yah, you are reading into it a little too much... The recommendation is to always install the better tires on the rear, but, lets be realistic, so long as the other two tires still have decent treadwear left, go ahead and rotate them... don't rotate them if they are worn below say 4 or 5/32's, just wait and replace... if above that, please rotate...
Caydoc
ES - 6th Gen (2013-2018)
03-04-19 03:54 PM
yjy4321
04-03-17 07:39 PM
HUS4144
03-19-16 04:23 PM
bowenn13
06-24-12 08:30 PM
VQT
SC- 1st Gen (1992-2000)
24
01-10-02 05:58 PM
Quick Reply: Michelin says to put 2 new tires on REAR... does that me I shouldn't rotate them?
