Tire Help - going for beefier tires...
Old 12-19-11, 05:22 PM
wum
wum's Avatar
Default Tire Help - going for beefier tires...
Hi Guys - well I decided to take the plunge and start modding my 06 IS350. First order of business is 19" rims and coilovers. I'm going with Forgestar F05s in 19x8.5f +35 and 19x10r +42. Seems like a lot of people go with 225/35/19 or 235/35/19 up front and 265/35/19 out back.
I'd like to drop the front so that there's just a 1 finger gap between the bottom of the fender and top of the tire - so not a widely aggressive drop. With a +35 offset (which is somewhat conservative, I think) can I run 245/35/19s in front without rubbing or fender mods? If so, can I run 275/35/19 in back with +42 offset w/o rubbing or fender mods? The rear will probably be slightly tucked so I don't end up with a rake (i.e., so the car remains level after the drop).
TIA
Mike
Old 12-20-11, 05:31 AM
zig@tr
Former Sponsor
zig@tr's Avatar
These sizes will require some fender modifications, probably pull fenders and reshape inner liners but I can't advise to the extent of modifications needed. 245 and 275 are just too wide for the stock setup. If you lower the vehicle to a "1 finger gap between the bottom of the fender and top of the tire", think of how little suspension travel that will leave you, this will make for a very stiff ride.
Old 12-20-11, 08:10 AM
wum
wum's Avatar
OK, thanks for your input Zig. i am looking for improved handling, but maintaining a somewhat comfortable ride. what do you recommend as the ideal front and rear tire sizes for what I'm trying to do? 225/35/19f and 265/30/19r?
Old 12-20-11, 09:34 AM
zig@tr
Former Sponsor
zig@tr's Avatar
225/35R19 will be ok in the front but the rear in 265/35R19 will be very difficult with zero modifications. 255/35R19 would be the ideal fit for the rear without modifying anything.
Old 12-23-11, 12:37 PM
onihc
I heart Honda
onihc's Avatar
i had 275/30/19 on the rear of my is250 with eibach drop. no shave or pull needed.
Old 12-24-11, 03:50 AM
c-low
c-low's Avatar
^^pics i would like to see what that looks like. if you want a sample here are a couple http://rimtuck.com/search/thumbnails...to=2008&sort=1
Old 12-25-11, 10:41 AM
onihc
I heart Honda
onihc's Avatar
i dont have many pics of my is250. you can check the garage in my profile. i had 235 in the front with slight rubbing, 275 in the rear on 19x10 +45 with zero problems.
tires were bridgestone re750.
cleethree
02-28-11 07:14 AM
mikemareen
07-30-07 09:15 AM
AJ
01-16-07 01:53 PM
Tim
01-04-06 01:37 PM
newyorksc
02-18-05 10:49 PM
Quick Reply: Tire Help - going for beefier tires...
