Work meister torque specs
Old 02-24-12, 08:59 PM
soarer13oy
soarer13oy's Avatar
Default Work meister torque specs
Im reassembling my work meister sp1 3 piece, and im trying to find the torque specs for the wheels. Thanks in advance
Old 02-24-12, 09:29 PM
laobo979
laobo979's Avatar
It's somewhere around 18-23lbs of torqure
Old 02-24-12, 09:51 PM
soarer13oy
soarer13oy's Avatar
Cool thanks il set it at 20lbs.
Old 02-29-12, 03:11 PM
soarer13oy
soarer13oy's Avatar
37 ft/lb is what the guys at work usa told me.
Old 02-29-12, 07:47 PM
Mr.Doback
Mr.Doback's Avatar
That should be the rating if they are new bolts and nuts, unless you asked specifically for used. Normally used bolts/nuts is 18-23ft/lbs as said above.
Old 02-29-12, 08:06 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
just curious why the difference in torque from new to used???
I've never seen any bolt have a different spec for new vs. used, regardless what we are talking about (wheels, suspension, anything...)
F_Throttle
Maintenance
03-23-15 02:15 PM
giolex300
01-16-13 11:39 PM
[ant]
06-18-09 03:25 AM
TexasGS
11-22-05 10:42 PM
LEXBERG
08-03-03 01:39 AM
Quick Reply: Work meister torque specs
