TPMS on AFTERMARKET WHEELS
Old 03-03-12, 08:04 PM
wuboy28
wuboy28's Avatar
Default TPMS on AFTERMARKET WHEELS
so i just bought a used lexus from a dealership. The check engine light is ON, due to missing tpms on the wheels . the salesmen told me. and he said he could provided me with the so called "straps" to hold the tpms. does anyone know what "straps" he is talking about? because i ask around and people have no clue.
thanks guys
Old 03-03-12, 10:28 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
thanks guys
Check engine light will never be set by anything wrong with the TPMS. TPMS issues will give you a tire light with an exclamation point and worst case scenario, the general warning light which is a triangle with an exclamation point.
Based on your thread title, the car has aftermarket wheels... most aftermarket wheels can have the TPMS sensors installed no problem, the ones that can't sometimes use a strap or an adapter to hold the sensor inside the tire... TPMS isn't as big a deal as your check engine light... definitely need to get that at least diagnosed to find out the issue...
Go to a car parts place and see i they can pull the codes for you, then report back to the maintenance section of Club Lexus and we can go from there...
To get TPMS working properly, you will have to install sensors in all the wheels, then have them calibrated to the car. Very doable, but the sensors aren't very cheap...
Aeromotive
11-07-14 10:39 AM
MyIS350G
02-02-11 08:43 PM
flektone
06-27-10 10:19 AM
Kevin.IS
08-09-09 03:19 PM
NYC ES3
12-13-08 11:42 AM
Quick Reply: TPMS on AFTERMARKET WHEELS
