Did these factory wheels have different offsets between GS and IS?
Old 05-26-12, 05:12 PM
BayAreaLex
BayAreaLex's Avatar
Default Did these factory wheels have different offsets between GS and IS?
I notice that both the GS and IS came with the wheels pictured below.
For the GS, the size was 17x8 50mm
What was the size/offset for the IS?
Thanks!
BayAreaLex
Old 05-26-12, 06:55 PM
BayAreaLex
BayAreaLex's Avatar
Doing a little googling, I found the following:
- The GS is a 17x8 while the IS is a 17x7
Both versions have a 50mm offset.
Maybe someone can confirm?
Old 05-28-12, 07:23 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
That is correct, there is also a 17x7.5" version that only came on the rear of sportcross IS's...
the wheels are different between the IS and GS though - the IS have more defined "channels" running the entire middle of the spokes...
bigblack06
11-09-15 09:12 AM
Ice350
06-06-06 05:21 PM
IAGS400
02-23-06 04:20 PM
SSK0771
10-05-05 11:09 PM
Quick Reply: Did these factory wheels have different offsets between GS and IS?
