Need info for Hub Rings!! 2008 ES350
I have a set of 20 inch Zenetti Lucre wheels and need hub rings I brought them off someone so local wheel shops aren't helping.. I need to know the bore of the wheel so i can order the correct rings..
The simplest solution would be to get a caliper or ruler that measures in millimeters. Then measure the center bore of the wheel and the hub of your vehicle, this will give you the size of ring you need.
As mentioned above... get calipers and measure the wheel bore. There are tons of these tings being sold on ebay. Just find the right size, match it to the 60.1mm Lexus hub, and place the order.
SCFactory
Performance & Maintenance
07-06-17 03:24 PM
