Will wheels Fitting 1996 SC300 fit a 2008 Camry?
The particular wheels I had on my 96 SC300 were 20" X 8.5 and 9.5 rears with a 40mm offset.
Is there a way to find out without trying the wheels on if they will work?
Thanks!
Thanks!
not going to fit...
everything is right except for the wheel widths... bolt pattern, center bore and offsets are all about the same - only issue is Camry's don't do well with wide wheels... chances are they will rub all the way around, depending on tire size, especially...
also, FWD cars look weird with staggered fitments, IMO
