'10 RX350 OEM wheels ?
Currently looking for a used set to use for Winter tires. OEM is 18" X 7.5", 5 on 114.3 mm bolt pattern. Can't verify the back spacing.
Question:
Can anyone tell me what other oem Lexus wheel will fit this vehicle ?
I'm seeing many available for the sedans but again, cannot verify if the back spacing will match.
Thanks for your help
Question:
almost any Lexus wheel will fit... my first choice would be to look for 16" older gen RX wheels... someone may be able to tell you for sure, but I don't think the brakes would be a clearance issue at all... ES, GS, IS wheels will all fit no problem...
might be cheaper to find a new set of aftermarket wheels though...
Cody,
Thanks for the reply. I could go with an older 16" but will need to find a tire just as tall as the 235/60-18. This shouldn't be a huge problem.
Any ideas on the back spacing for the models other than the RX ?
a 235/70-16 will be within a tenth of an inch and would fit on an OEM 16" RX300 wheel no problem... just gotta make sure it will clear the brakes is the only potential issue I see...the best part about 16's is that tires are sooo much cheaper... Blizzak DM-V1's in that size are only $536 for the set from Tire Rack right now...
A 235/60-18 Blizzak locally is $300.0 + install + HST @ 13%.
I can get them sent to Calais, Maine & retrieve them myself for about $166.00 + 15% duty/tire. Install locally will cost about $100.00/4.
I'll keep looking around on-line, perhaps post an ad here under "Wanted".
Local dealer has a Winter wheel/tire special running currently.
4 OEM wheels, Blizzaks, centre caps,TPMS units, lug nuts installed & balanced for $3295.00 + 13% HST.
Cheers,
Working on a deal for 19" OEM RX350 wheels. Includes centres, TPMS, lug nuts & locking lug nuts. Splitting hairs on the overall tire height 235/60-18 (29.1") vs. 235/55-19 (29.2").
Speedo difference would be zero or very very near zero.
Speedo cable driven like my old '71 Buick or are they digital/analog signals ?
Just closed what I think is a sweet deal.
4 X '11 19" rims in mint, mint, condition. TPMS, centre caps, lug nuts & locking lug nuts.
$900.00 + ship.
$900.00 + ship.
Thanks.
Brewdog
RX - 3rd Gen (2010-2015)
06-18-11 03:43 PM
