Help - Where can I buy some centering Rings?
I have a vibration at 50 -60MPH
The guy at the shop showed me that the wheel is balanced and the problem is that when you toss in on the hub it moves slightly back and forth. To get rid of this you need to get hub centering rings.
The problem is the shop where I bought the rims is closed??? Gone???.
I have quality rims and just need someone that knows where I can either try some sizes out or that sells SSR and knows what sizes I need.
I have a 2000 GS400 w/ SSR Agle Strusse 18" Rims.
I sent an email to RMM. Hopefuly someone can help.
http://www.prestigewheel.com/HubRingsbyMake.asp
Sent an e-mail to these guys as well.
They seem to sell all the sizes for any car.
Doesn't anybody know what size i need?
Anybody running SSR rims on a 98+GS????
Just need to know what the Wheel Bore is on the SSR rims.
Anyone???
Make Model Year Bolt Pat WheelBore HubSnout Part#
LEXUS GS 300 93-on 5x114.3 71.12mm/2.800 60.06mm/2.365 HR71-6006
LEXUS GS 300 93-on 5x114.3 66.06mm/2.600 60.06mm/2.365 HR66-6006
LEXUS GS 300 93-on 5x114.3 67.00mm/2.638 60.06mm/2.365 HR67-6006
LEXUS GS 300 93-on 5x114.3 69.85mm/2.750 60.06mm/2.365 HR69-6006
LEXUS GS 300 93-on 5x114.3 70.00mm/2.755 60.06mm/2.365 HR70-6006
LEXUS GS 300 93-on 5x114.3 76.00mm/2.992 60.06mm/2.365 HR76-6006
LEXUS GS 300 93-on 5x114.3 72.62mm/2.859 60.06mm/2.365 HR72-6006
LEXUS GS 300 93-on 5x114.3 73.00mm/2.8701 60.06mm/2.365 HR73-6006
LEXUS GS 300 93-on 5x114.3 74.00mm/2.913 60.06mm/2.365 HR74-6006
LEXUS GS 300 93-on 5x114.3 75.00mm/2.950 60.06mm/2.365 HR75-6006
Anyone???
Registered User
adr wheels makes hub rings, but almost any good rim shop should have this item... sales@adrwheels.com
you don't really need hubcentricity since you can use your lugs to center the wheel. basically snug one lug while you shake the wheel back and forth, snug another while shaking, and again, and you should see that it's got lugcentric mounting.
however, if neither lug- or hubcentricity works, then it could be the way the tire is mounted on the rim. for this you will need to find a tire shop with a hunter roadforce balancer... www.gsp9700.com
OK I see what the problem is.
The GS side is 60MM
The SSR side is 60MM
There is no adapter nessasary.
And yet I have play when the tire is on the hub and vibration at 60MPH.
So something is way off. the SSR side can't be 60mm like RMM is saying.
There is no bends in the rims. they are true.
The wheels are balanced and they are all properly torqued on all four.
I'm stumped.
I really don't want to take off a wheel and mesure this but it will most likely be the only straight awser I will get.
After talking with three separate shops that carry my rims no one can help me out.
I also drove just fine for the first two years of ownership of these rims.
The GS side is 60MM
I'm stumped.
i have few spare ones that i can sell you...work so far on many JDM wheels...though not sure if they would solve the problem since the wheels were fine as you mentioned
check the tires?
I had a similar problem... Everything was fine until I replaced the front tires. It started wobbling and etc... I ended up getting another set and it was fine.
the wheel balancer is telling me that the wheel and rim are OK.
But, I hear what you are saying that it could still be the tire.
since they rebalanced and retorqued it is almost gone.
It's just weird that the shop pointed me in the direction of the
centering rings and I hit a dead end in that direction.
I did not purchase the tires from the shop so It wont be easy to
just get another pair of tires. I will just have to avoid this brand
in the future.
in the future.
